Epad-phone
Hi... Welcome onboard. Sorry to hear about those annoying messages. Have you check to see if you're device is in any way associated with A/C. Its worth a shot. However, if it's not stopping you from doing Whatever you need to be done, then you should try to ignore it. Delete delete... :)
Do you have your Google account associated with the Android market. You won't be able to use the market without first signing in.
Silly question from D-U-R-X time... have you added your gmail account to your device? That should let you on the market...
EDIT - Rushrl get's in there first again!!
Welcome to Android Forums?
Do you have the market on your ePad? Some of the import tablets (in the U.S.) do not have access to Google's Android Market because they didn't want to license access. Instead they choose to set-up their own app repository for you to download apps from. For the Market to list your devices in your profile, you must have your device registered with a Google account (usually gmail), and it must have market access. Then using the same account, log into the market.
