Help EPIC 4g bluetooth disconnect
vxl65703
I purchased the EPIC 4g a couple of weeks ago, along with the Samsung wep 450 blue tooth. I noticed that when the bluetooth is not is use it will suddenly disconnect from the phone. I get the message paired but not connected. This happens at home or in the car. I actually had the bluetooth sitting next to the epic on my kitchen table and it disconnected. I can make an initial call using the bluetooth and then when I hang up and try to make another call it gives the connection error. To fix it I have to go into wireless connection settings click on the device to connect it again. I always have to hit the device twice to get it to connect it never connects on the first try.
has anyone seen this before. Not sure if I have a defective bluetooth or corrupt EPIC OS.
thanks in advance for your help.
