Epic Haiku Settings
How can I access the menu while inside the Epic Haiku app on the Galaxy Note 4?
Where is the "Menu" button??
The menu button has been replaced (or enhanced, depending on your point of view) by the "recent apps" button.
You can access the menu button in most apps by long pressing the recent apps button.
Also, most apps will have 3 stacked dots in the top right corner of the display. Pressing on this icon will generally give you the same option pressing the menu button would present.
Random example I googled:
