hi -
i had mounted my sd card to transfer files between pc (XP) and eris.
i correctly unmounted from pc (safely remove hardware) and then stopped file sharing on eris.
i took the card out and put in a different one (i don't have a card reader and was trying to transfer some stuff).
when i tried to put the original card back in, my finger slipped as i was pushing it in and it got like halfway in and then popped back out.
the eris saw this as an unsafe removal.
now, it keeps telling me "the sd card is blank or using an unsupported .." something. if i tap on the notification, it just takes to me a window to format it. i keep saying yes to format, but it never formats.
i've tried formatting from settings and tried mounting it again and formatting from the pc. when i do that, the pc says that the drive size is 1.08 TB (?!?!?). this is the 8GB sd card that comes with the eris. and it also won't let me format.
what gives? i've tried taking it out and putting it back in. it keeps saying unsafe removal but the option to unmount is grayed out and i can't choose it.
i tried taking it out, turning off the eris, putting the card in and turning back on. still nothing.
what's going on here????
