Apps Error - android.os.NetworkOnMainThreadException
gimomars
Hi I'm new with android development, I'm trying to create a simple CRUD using WCF. But I've received the error : android.os.NetworkOnMainThreadException. I think there's a problem in threading.
Can you help me guys? Here's my code. The error occur here :
HttpResponse httpResponse = httpClient.execute(httpGet);
public boolean verifyLogin(String username)
try
DefaultHttpClient httpClient = new DefaultHttpClient();
HttpGet httpGet = new HttpGet("http://localhost:89/Service1.svc/checkLogin?name="+ username +"");
HttpEntity httpEntity = httpResponse.getEntity();
InputStream stream = httpEntity.getContent();
String result = convertStreamToString(stream);
if (result.charAt(1) == '1')
Toast.makeText(getApplicationContext(), "Success", Toast.LENGTH_LONG);
return true;
else
return false;
catch(Exception e)
return false;
Thanks
