Error in android?
I wanna play some N64 games on my android.I tried to install N64oid from a .apk file, but it said"Application not installed", and the same happened with temple run.Then I installed Mupen64plus.But I can't play, when ever I launch a Rom, the screen is black at start, and slowly sound comes, but at very low fps, and no video output, with a white screen.And soon after that, I launched the rom again, but this time the emulator crashed.This was happening again and again./I posted the same thing 2 times, but no replies.So I decided to post with a little more detail.
1) You may have a bad phone, and it doesn't have enough memory/processor power to run the game
2) Your device might not be supported by the emulator (see because of #1)
3) Depending on where you downloaded the .apk from, it could just be malware.
My guess is probably #1. Which phone do you have?
lol, you know the score. It's the phone, I bet my life :D
P.S - sorry, i've been drinking beer...:smokingsomb:
K.
Its MTS Mtag 3.1, released 6 months ago in India.
And, it can't be malware, since at first I tested the .apk, and the same happened.And then, after thinking that it might be malware, I downloaded 3 more .apk files.But the same happened.
And, I don;t think it is a bad phone, since most android apps work really well.
It's the phone. You have a 2.8 inch display and think it's a top end device?? That's a low end device if I've ever seen one. Of course it won't run top end apps. Sorry, no go.
800 MHz processor
2.8" display
256 MB RAM
Yeah, I understand, since most of the -oid games including gameboid, nesoid, gearoid, worked, so I expected N64oid for the same.
Thanks anyway, if there is any solution, I would be happy to know.Thanks again.
