Help ERROR no boot no charging of battery
ORD84
Ok so I just got the phone today, and after I tried to root it using the apk file found here [APP] z4root - xda-developers instead of z4 root like a buddy suggested not too long ago...I just wanted to remove some of the pushed apps that VZW has
anyways long story short I downloaded said apk file from above link, phone's battery went dead I think ok no problem, plug it into the work computer to charge, now I get a message that reads bootloader 30.04 battery low cannot program (with battery low can't program flashing)
How can I fix this problem while I'm still at work? I just got this phone today after my Incredible's speaker blew as a replacement phone...
Thanks in advance
OK nothing wrong with the app. When you install the app you need to reboot before applying Z4Root. Sometimes it does not work the first time and you might need to pull the battery. Regardless you have a problem right now. Your X will not charge when in the bootloader mode. If the battery is low your phone will not respond period. First see if you ahve enough pwoer to boot into recovery. Power the X down then hold the power and home button at the same time. If the S bots into recovery it the screen will have a yellow triangle with an exclamation point. Press the search button and you should get a menu of options. Scroll to factory reset by using the volume button then press the camera button. If your X does reset then you should be able to charge the battery and start over on the Z4Root. If this does not work you need to find a way to chrge the battery out of the X. Go to Verizon and ask them to charge it for you.
