A Android Question Guest Aug 14, 2016 #1 Keep getting a pop up that says "Unfortunately %1s, Tab %2$d of %3d has stopped." I can only OK or report. What is this and how do I stop it?
AZgl1500 Extreme Android User Aug 14, 2016 #3 Restart the phone.... hopefully that will fix the problem. if it persists, do an FDR so it comes back up in pristine, OEM condition. then the problem will be gone.
S Steve888 Lurker Aug 14, 2016 #4 AZgl1500 said: Restart the phone.... hopefully that will fix the problem. if it persists, do an FDR so it comes back up in pristine, OEM condition. then the problem will be gone. Click to expand... It is a samsung tab4 10.1. If I do a FDR won't I loose everything on it?
