Android Version: 2.3.7
Network: T-Mobile (unlocked)
Taskiller Used?: unsure
[Optional]Are You rooted & which Rom: Yes, CM7.2.0.1 Bravo
Issue: Error connecting to mobile data.
Hey i've recently developed a problem with my rooted HTC Desire. Whereby the mobile data connection is dodgy at best and nearly most of the time is disconnected. I can connect to WiFi fine but returning to mobile data will result in 4 light grey bars which indicate signal but it wont connect. Pictures below.
Can't be a software issue because i've been running CM7.2.0.1 bravo for a while now with no data issues whatsoever. Occasioanlly i'll get no service and when i try to search for networks it takes a really long time to come up with results and usually when i does show them and i try to connect i get " error while searching for networks"
Any thoughts?? I did think about backing up all data and flashing cm7.2.0.1 again but looking at other threads that didn't solve the problem:
Wifi And Data Issue - HTC Desire GSM Stable Mod - CyanogenMod Forum
Any thoughts on a solution?? It's bearable at the moment but i'd prefer it to work properly.
