545himanshu
I trying to add ics task manager in framework-res but when i try to recompile it's gives error like this
C:\andro\apktool>apktool b framework-res
W: Could not find sources
I: Checking whether resources has changed...
I: Building resources...
aapt: warning: string 'zzzz_agold_chinese_cal_day_1' has no default translation
in C:\andro\apktool\framework-res\res; found: zh_CN zh_TW
aapt: warning: string 'zzzz_agold_chinese_cal_day_2' has no default translation
aapt: warning: string 'zzzz_agold_chinese_cal_day_3' has no default translation
aapt: warning: string 'zzzz_agold_chinese_cal_day_4' has no default translation
aapt: warning: string 'zzzz_agold_chinese_cal_month' has no default translation
aapt: warning: string 'zzzz_agold_chinese_cal_month_1' has no default translatio
n in C:\andro\apktool\framework-res\res; found: zh_CN zh_TW
aapt: warning: string 'zzzz_agold_chinese_cal_month_10' has no default translati
on in C:\andro\apktool\framework-res\res; found: zh_CN zh_TW
aapt: warning: string 'zzzz_agold_chinese_cal_month_11' has no default translati
aapt: warning: string 'zzzz_agold_chinese_cal_month_12' has no default translati
aapt: warning: string 'zzzz_agold_chinese_cal_month_2' has no default translatio
aapt: warning: string 'zzzz_agold_chinese_cal_month_3' has no default translatio
aapt: warning: string 'zzzz_agold_chinese_cal_month_4' has no default translatio
aapt: warning: string 'zzzz_agold_chinese_cal_month_5' has no default translatio
aapt: warning: string 'zzzz_agold_chinese_cal_month_6' has no default translatio
aapt: warning: string 'zzzz_agold_chinese_cal_month_7' has no default translatio
aapt: warning: string 'zzzz_agold_chinese_cal_month_8' has no default translatio
aapt: warning: string 'zzzz_agold_chinese_cal_month_9' has no default translatio
aapt: warning: string 'zzzz_agold_chinese_cal_month_one' has no default translat
ion in C:\andro\apktool\framework-res\res; found: zh_CN zh_TW
C:\andro\apktool\framework-res\res\layout\recent_apps_dialog.xml:4: error: Error
: No resource found that matches the given name (at 'id' with value '@id/zzz_rec
ent_application_title').
C:\andro\apktool\framework-res\res\layout\recent_apps_dialog.xml:8: error: Error
: No resource found that matches the given name (at 'id' with value '@id/zzz_but
ton_job_manager').
: No resource found that matches the given name (at 'text' with value '@string/j
ob_manager').
C:\andro\apktool\framework-res\res\layout\recent_apps_dialog.xml:11: error: Erro
r: No resource found that matches the given name (at 'id' with value '@id/zzz_re
cent_app_icon_row').
C:\andro\apktool\framework-res\res\layout\recent_apps_dialog.xml:12: error: Erro
C:\andro\apktool\framework-res\res\layout\recent_apps_dialog.xml:33: error: Erro
r: No resource found that matches the given name (at 'id' with value '@id/zzz_bu
tton_job_manager_second ').
r: No resource found that matches the given name (at 'text' with value '@string/
job_manager').
Exception in thread "main" brut.androlib.AndrolibException: brut.common.BrutExce
ption: could not exec command: [aapt, p, --min-sdk-version, 10, --target-sdk-ver
sion, 10, -F, C:\Users\ALIEN\AppData\Local\Temp\APKTOOL4917122119676883933.tmp,
-x, -S, C:\andro\apktool\framework-res\res, -M, C:\andro\apktool\framework-res\A
ndroidManifest.xml]
at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.jav
a:255)
at brut.androlib.Androlib.buildResourcesFull(Androlib.java:324)
at brut.androlib.Androlib.buildResources(Androlib.java:269)
at brut.androlib.Androlib.build(Androlib.java:192)
at brut.androlib.Androlib.build(Androlib.java:174)
at brut.apktool.Main.cmdBuild(Main.java:188)
at brut.apktool.Main.main(Main.java:70)
Caused by: brut.common.BrutException: could not exec command: [aapt, p, --min-sd
k-version, 10, --target-sdk-version, 10, -F, C:\Users\ALIEN\AppData\Local\Temp\A
PKTOOL4917122119676883933.tmp, -x, -S, C:\andro\apktool\framework-res\res, -M, C
:\andro\apktool\framework-res\AndroidManifest.xml]
at brut.util.OS.exec(OS.java:83)
a:253)
... 6 more
ton_job_manager').
ob_manager').
job_manager').
ndroidManifest.xml]
a:255)
a:253)
... 6 more
