Hi. I'm some kind of new at the Java language and to the ANDROID. I was checking the samples that comes with the SDK and that of the accelerometer caught particulary my attention, but once I tried to run it to see what it does, appeared that I've got 2 errors:
-The method onAccuracyChanged(Sensor, int) of type AccelerometerPlayActivity.SimulationView must override a superclass method AccelerometerPlayActivity.java /AccelerometerPlay/src/com/example/android/accelerometerplay line 457 Java Problem
-The method onSensorChanged(SensorEvent) of type AccelerometerPlayActivity.SimulationView must override a superclass method AccelerometerPlayActivity.java /AccelerometerPlay/src/com/example/android/accelerometerplay line 378 Java Problem
And 1 warning:
-Attribute minSdkVersion (5) is lower than the project target API level (10) AndroidManifest.xml /AccelerometerPlay line 1 Android ADT Problem
I will really apreciate any kind of help!!!!!!!
And 1 warning:
