Every one posts a screenshot of their Note's Home Screen please!
iSergiwa
Member
Just for fun, or maybe to know what apps and themes each Note user frequently uses, hence learn from each others' experiences. Also, I believe that a person's home screen says a lot about their character. So this would be a good chance for this forum's members to get to know each others (if they are by any chance interested in that lol)
Here we go, mine is in the attachments...
I have two main screens I work from...
Omar Days, Dreamy home screen, a bit gloomy though!
McGilli, Nice home screen, not so well-arranged but looks pretty similar to mine except I don't use wallpapers at all for the sake of clear view and battery life. I like mom & dad direct dial shortcut btw :)
iSergiwa
The widget to the upper left of your screen showing 'Active applications' looks interesting; would you tell us what it is please?
Incidentally, you can see quite a few screens at :-
http://androidforums.com/samsung-galaxy-note/497178-show-us-your-screens.html
I didn't know about that thread otherwise I wouldn't have started mine. But I think it doesn't hurt to start a fresh one anyway.
The 'Active applications' widget is the built-in widget for monitoring active apps. You know, not all apps have a soft Exit button, so I just press home button and then tap on the widget and click Exit.
Thanks for sharing
McGilli, can you tell me what widget you're using for the system volume levels on your second screenshot? Looks interesting.
Another one of these. Here's mine:
Go Launcher
Mahogany theme with the leather backdrop from one of the glass themes.
Widgetsoid for the toggle bar down the right (Hundreds of things you can do with it).
Sense Analog Glass Clock.
WeatherLove.
bodestone, what toggle widget is that? i like that more than my one because i can only have up to 8 different widgets.
