This is a Note 4 (unlocked from AT&T, running Android 5.0.1). Yes, it's a few years old but I use it only as a pocket-sized drawing tablet and it has worked mostly great for that purpose (using ArtFlow), up to a year or so ago. Since that time there were problems that made me stop using it. First, every time I reboot, it starts with a message "Android is upgrading... Optimizing app 1 of 1" for the first few minutes, which obviously slows down the boot process, and also makes me wonder if something is "stuck" in the operating system. Second and more important, it was extremely sluggish, to the point of unusability. Third, all the batteries were inflated.
Just recently I decided to try using this device again, since it is my only portable stylus-based device so I want to use it for sketching. I bought a couple new batteries, so there's one problem solved. I read an article on Android performance, and cleared the cache; and now performance seems much improved, though still a bit laggy at times. And I assume that recurring "Android is upgrading" message is a sign of something I need to fix, but I don't know where to start.
Also I do have "Developer options" enabled, and under "Process stats" it shows a huge number of applications running at 90+%, including Instagram, Amazon, AT&T Locker, etc. etc., none of which I use, as far as I'm aware. It says "the status of your device memory is currently critically low". Should I do something to stop all these seemingly unnecessary processes?
Any suggestions appreciated! There are plenty of apps on the device, almost none of which I use. They have a very small footprint on the device storage so I never bothered uninstalling them, but I suppose uninstalling them might help eliminate some of those "processes".
