oxfordaxemonger
Hi, so I'm on an epic quest to simply get a better camera app on the EVO 3D.
It's not my actual phone, I just wanted to teach stereoscopic photography to some high schoolers.
But I don't like the stock camera app — photos are blurry and the shutter takes too long — so I thought I'd try the Amaze Camera app port for the EVO 3D.
Unfortunately, I updated to ICS, which the Amaze Camera doesn't work in.
So I'm trying to downgrade, using this guide.
To do that, I need to unlock the bootloader. To do that, I'm using HTC's guide.
I'm stuck at Step 5, where I open up Terminal and type "fastboot oem get_identifier_token"
It responds: "-bash: fastboot: command not found"
I've tried the whole set of instructions several times. I've tried using a different cord. I've made sure "USB Debugging" is turned on and "Fastboot" is turned off. I used this to help install Fastboot and ADB commands on my computer. I also installed the entire SDK.
I'm on a 2014 MacBook Pro, running Yosemite.
Any ideas would be much appreciated! Thanks!!
