Help evo 4g mms not downloading
freshpl
as the title says, if i have wireless network off and i get an mms then turn on the 3g network it won't download just keeps saying downloading...
I am having the same problem....called HTC and they said.it might have to do with the Android update 2.3.3 (I think that's the right number).... anyways very frustrating
I had the same issue and if I disable WiFi it seems to help. Not really a solution but possibly a work around until Sprint can address it. You're not alone though if you search the internet.
