Accessories Evo Case Recommendations
Flash77
Member
I'm looking for an case for my Evo, but one that doesn't cover the power and volume buttons. Any suggestions?
the body glove case is terrible. i had it for 2 days and it broke. the plastic is very flimsy and wont withstand much. best buy has the platinum series cases which arent bad. im using the flexi skin and i prefer that, but the buttons are covered
I went with the platinum series from best buy. It has a snug fit and the buttons are not covered!!!! Thanks for the suggestion.
I've got a Seidio Innocase-Active, for 30 bucks it aint bad.
I'd prefer something even sturdier though in the long run.
