stevenflaugher
Is it possible to hook up my EVO to my car stereo (there is an AUX outlet on it) to play music through the stereo? If so, what kind of connecting cable will I need?
Thanks a lot. I'll check these out.
Does anyone know if the sound quality is similar to playing a CD?
Griffin is a decent brand, that's the brand I'm using right now. I purchased a Dynex one (Best Buy brand) but that one went out on me after a week of use or so. Also Monster (known for their quality) makes them as well, though I'm pretty sure they might be a bit more expensive than the other brands. But honestly, any brand would do just fine, just make sure the actual build of the cable is good quality, and you shouldn't have any problems.
$1.99 shipped. It is nice because it is only 3ft and has a 45 degree angle on one side. I have tried several cables and this type is by far my favorite.
Ebay search "3mm aux cable"
3FT 3mm AUX AUXILIARY CABLE CORD FOR iPOD MP3 MP4 MP5 - eBay (item 140408838828 end time Jul-16-10 20:38:15 PDT)![]()
Check out www.monoprice.com for all of your cable needs. I've blown so much with them over the years. Now you will too! I only wish they had a micro HDMI cable.
I have no stereo sound, left speaker only (Pandora) do you have same problem
