conor.in
UPDATE: My phone now works normally. It finally acknowledges cables and charges again. Still no idea what the issue was.
My Evo will no longer recognize a charger or turn on. Without being plugged into the wall, the power button does nothing. Even when it is plugged in, it will turn on, flash the white "HTC EVO 4G" screen for about half a second, and then turn off. When plugged in the notification light does not come on.
I've tried charging using any combination of the following cables and USB wall chargers, and at different outlets, and nothing has worked.
- Apple iPod wall charger
- HTC OEM wall charger
- Palm Pre OEM wall charger
- HTC OEM USB cable
- Palm OEM USB Cable
- Aftermarket USB Cable
The only real idea I have to what's going on is that the charging port somehow got broken, but that seems strange to me because it worked when I woke up, allowing me to send a few texts. I left my room for a few hours, and when I came back the Evo was dead.
Any ideas as to what's wrong?
I've tried to be through, but if you need more information I'd be happy to try and give it to you.
- HTC OEM USB cable
