albert1014
Dear Madam/Sir,
I have some codes section as below :
HttpClient client = new DefaultHttpClient();
StringBuilder builder = new StringBuilder();
HttpGet myget = new HttpGet(http://test123abc.comoj.com/json_test.php);
try {
HttpResponse response = client.execute(myget);
catch (Exception e) {
Log.v("url response", "false");
e.printStackTrace();
Every time I run this codes with AVD under Eclipse, it will always drop into the catch function with exception.
I tried to debug, then found that the problem happened after executing the code "HttpResponse response = client.execute(myget)".
After I saw some suggestion on internet, I added the following code in the AndroidManifest.xml which is outside of the <application> section.
<uses-permission android:name="android.permission.INTERNET" />
But the same exception happens.
I want to know if there is any other reason to cause this problem.
I think this should be the simple question but I am just the beginner in Android development.
So please help me with any suggestion or checking point.
I will appreciate your any help. Thank you very much.
try {
