700M for the hotspot? Possibly the PC or whatever you were tethering was downloading data, like 'patch Tuesday' Windows security updates or the Windows 10 upgrade or something.Suddenly today my data usage shot up to 1.4 gigs in a half-hour period. 700m for my hot-spot and 700m for "OS Services". I have no idea what this is. I would appreciate an explanation, I'm not happy, as I didn't do anything that would account for it.
Thanks,
Mick Berg.
If you're using large amounts of data with your hotspot, that's not suspicious. The laptop or whatever you're tethering was using the data, that's what's going on.Thanks for your replies. I wish they would just tell us what was going on. But I guess there's nothing suspicious.
Mick Berg
I have had this problem on all 3 of my Android tablets for years, and now with my Android Smart Phone. I normally keep WIFI turned off except during my "free" data period (3 am to 7 am), otherwise I blow my allotment. Tonight, I had to turn on WIFI in my Samsung Galaxy 2 at a little after 9 pm, and even though all auto-updates are turned off (OS & Apps) it downloaded 100 Mb of something in several minutes. I think I have finally figured out what it is. You can turn off Auto-updates of Apps, but you can not keep it from "checking" for updates. So, how does Android check for App updates? It re-downloads each App to compare to the existing App to see if update is needed. If Auto-update is ON, it keeps the new download and discards the old, but if Auto-update is off, it just marks the App as needing an update, and discards (wastes) the new download and wastes your bandwidth in the process.
