Root Exchange a kernel: unstable memory management
Hallo,
I am currently running the stock ROM of (on http://androidforums.com/wildfire-s...e-apps2sd-premium-features-2.html#post5720923 ) but unfortunately it is unstable and crashes regularly (already after hours and then only after days, often absolutly from alone without touching it).
(actually it runs 'so well' just because I decreased the cpu rate to 480 MHz (otherwise I could not even boot it properly))
I reinstalled it (with TeamWin recovery) several times. No chance!
I am wondering here very much because others say that it runs perfect on their WFS. How can this be possible?...
I am quite sure that there is a bug of the memory management in the kernel 'RUU Marvel S' !! (actually it is NOT the SD card or Data2SD !)
Does anybody has an idea...
* what can be another reason?, or
* if there is an updated stable running version of this stock rom?, or
* if there is a tool that I can use to test to find out the problem?, or
* if there is another fitting kernel I can exchange this one with?
My telephone identity says: 'HTC Wildfire S A510e'.
My SD card partitions are well configured for installed Data2SD (e.g. all are primary, etc.).
Does it help to use e.g. the 'cake' kernel? I have read anywhere about it...
Can I just flash it so that it exchanges the existing one?
How can I find its download, or of another fitting kernel?
Thank you so much for any useful advice!
Best wishes.
