Help Exchange ActiveSync - can't specify a port?
deanl70
Hi
I am wanting to connect the activesync to my works exchange. I need to use a non-standard port (81 or 82) to connect to the exchange server. As soon as I put the colon in the exchange server address, the next button greys out.
Has anyone found this or found a solution??
Thanks
I have the same problem, as does everyone with 2.1 update I guess. I think this was possible with 1.6. Why you would take away this functionality is beyond me. I tried using Roadsync, but since I'm in Norway I can't buy the software and the demo-version has run out. I tried Touchdown, which you actually can buy on the website, but this will not let you use a custom port either. It can't be that hard to implement? There's a $20 in it for anyone who does...
EDIT: I finally found software which could do it, Exchange ActiveSync on your G1! | Nexeo.net
