Exchange task synch
I synch with our corporate Exchange server, and have been impressed with email, contacts, and calendar integration. I am trying to find an app to synch with tasks on the Exchange server. The only one I have found is Touchdown which replaces email, contacts, and calendar also. Is there a good stand-alone app for to-do/task synch with Exchange server?
I contacted Touchdown tech support and got a solution for this. I tested it myself and it works on my phone at the very least. Inside Touchdown, you have to go to Settings >> Advanced. Then you have to scroll to the bottom and click "Choose folders..." From there, you can pick what folders to sync and Tasks is a folder there. If you pick tasks, you tasks will sync automatically. You may have to click on "Refresh Folders" to get the full folder list. Hope this helps.
Upvote 0
BEST TECH IN 2023
Smartphones
