Apps executing self-compiled c/c++ code in connectbot: Syntax error: word unexpected
piggebu
Hi all,
(see at the end for setup and device info)
I am trying to compile my own c/c++ code and run it on my android phone.
I got the android toolchain and the program (hello world, "test" binary) compiles:
./agcc -c -o test hello.cpp
file test
test: ELF 32-bit LSB relocatable, ARM, version 1 (SYSV), not stripped
The program executable is "test". I copy it to my android to /data (since other folders apparently do not have execution permission yielding the "permission denied" error when trying to execute) and do "chmod a+x test"
When I start connectbot on my phone, navigate to /data and do "./test" then I get the error: Syntax error: word unexpected (expecting ")")
As if connectbot would try to execute this binary as a shell script.
In principle, a step-by-step manual how to compile and run c/c++ code on android would be available
But I get this strange error mentioned above.
any ideas?
setup:
Phone: Samsung Galaxy S2
Android: 2.3.4
Kernel: GINGERBREAD.XWKI4 (rooted, works all fine)
Crosscompile Toolchain: from google
Using agcc script from "plausible . org/andy/agcc"
Exporting: export PATH=[PathToToolchain]/prebuilt/linux-x86/toolchain/arm-eabi-4.4.3/bin:$PATH
Hello World example:
// hello.cpp
#include <stdio.h>
int main()
int a=1;
printf("hello %d",a);
return 0;
compiling with: ./agcc -c -o test hello.cpp
