jon80
Member
Error
7, 23) Execution failed for task ':Application
rocessDebugResources'.
> com.android.ide.common.internal.LoggedErrorException: Failed to run command:
C:\Users\slyth_000\AppData\Local\Android\sdk2\build-tools\21.1.1\aapt.exe package -f --no-crunch -I C:\Users\slyth_000\AppData\Local\Android\sdk2\platforms\android-21\android.jar -M C:\Users\slyth_000\AndroidStudioProjects\Camera2Basic\Application\build\intermediates\manifests\full\debug\AndroidManifest.xml -S C:\Users\slyth_000\AndroidStudioProjects\Camera2Basic\Application\build\intermediates\res\debug -A C:\Users\slyth_000\AndroidStudioProjects\Camera2Basic\Application\build\intermediates\assets\debug -m -J C:\Users\slyth_000\AndroidStudioProjects\Camera2Basic\Application\build\generated\source\r\debug -F C:\Users\slyth_000\AndroidStudioProjects\Camera2Basic\Application\build\intermediates\res\resources-debug.ap_ --debug-mode --custom-package com.example.android.camera2basic -0 apk --output-text-symbols C:\Users\slyth_000\AndroidStudioProjects\Camera2Basic\Application\build\intermediates\symbols\debug
Error Code:
1
Output:
C:\Users\slyth_000\AndroidStudioProjects\Camera2Basic\Application\build\intermediates\res\debug\layout\layout.xml:4: error: Error: No resource found that matches the given name (at 'hint' with value '@String/to').
rocessDebugResources'.> com.android.ide.common.internal.LoggedErrorException: Failed to run command:
Error Code:
1
Output:
