The instructions are right in the manual - Settings > Mobile Networks > Network Mode. Enable "GSM Only" and you will disable 4G/3G and only be using the EDGE network (2G).
I have the 1st Exhibit, and to tell the truth I've never seen 3G on my phone.
It's either 4G or Edge...I even Googled it once to see if it even had 3G, never found anything.
On the plan I picked was 3G, and I get 3G. If I am out in the country or something my phone will sometimes switch over to EDGE.
There is an app you can download, called power control. I use it for the screen brightness settings and to watch the percentage on my battery.
but it also has a button to let you switch between 2G and 3G :]
