Help Exif data
  • Thread starter Thread starter Exif data changing
  • Start date Start date
E
Exif data changing
Guest
Hello, android folks. I have a question, i've downloaded app which is called EasyMerch V2 from play market. This programm is usually gets in use for work with merch. This app sends photos made inside there, not from standard camera, but from app and sends it directly to some server. I need to change EXIF data on photos, i can do it with photos made by casual camera app (it saves it to gallery) but in EasyMerch there is no photos in there, you just make pic of something and then you can only press "Send". Where do these photos store and can i actually change exif data?
So the images are generated on the fly by the EasyMerch app, as it uploads to their remote server on the internet? So there is nothing stored locally on the device that you can modify or edit. Frankly I don't think there's anything you can do with that, unless you're the app's developer.
Yes you can't do it if the app doesn't store the photos locally before transferring them over the Internet.
