Help Expandable storage (Micro SD) limit
I have been seeing inconsistent amounts for the storage limit on the stylo. Currently on both the metro pcs and tmobile websites it says it has Up to 32GB Expandable Memory. On literally every review before it came out it says 128GB or up to 2TB. Whats strange is I also saw a review where they had a screen shot of tmobiles first specs on it when it said up to 128GB or 2TB. Has anyone one tried to put any micro sd card on it above 32GB like the 64 or 128. If so let me know. Thats my only deciding factor for this phone.
on a side note not sure what prefix this would be considered....
I have Boost Mobile version. I have not Activated it yet - waiting until end of month to leave Virgin Mobile. I just bought a 32BG microSD online so I hope it works. The Boost site says it's version supports up to 32GB. I notice the T-Mobile and MetroPCS versions have higher specs for their versions of the phone like 2GB of RAM, 16GB of internal storage and a 12MP camera, etc. Point is, there is different versions of this phone dependent on the carrier it is for.
LG G Stylo (US)standard support is 32g but u can go as high as 128 the 2Tb its for the G4 stylo UE & Korean versions
The reason they state that cards only up to 32gb are supported us because cards larger than that come formatted to ntfs format by default, which Android (by default) can't read. All you need to do is format the larger card to fat and it should work no problems
ok cool I'm gonna buy a 128gb soon then. Im wondering if that will work with my f6.
i haven't heard about Stylo been compatible with 128gb sdcards so take that in consideration if you buy it from a local store that will be a better idea just in case doesn't work and need to be return or exchange for a 64gb sdcard, just my 2 cents
For practical purposes there is no sd size detect limit nowadays.
If a phone can handle 32, it can do larger sizes.
This should no longer be a worry, esp. with the top brands.
If you think I'm wrong feel free to put me in my place.
I've got a 128 GB on the way,ETA 7/14/15:
Lq3HEna0L88XPrLe9IFoMhr7wWLvrGktF_vrF38TFjX37B-CNhaWhiy5Y_ckjTxo2l0ZQA=s96
http://www.bhphotovideo.com/c/produ..._128gb_hi_performance_sdxc_uhs_1_card_60.html
I'll post my findings regarding formatting/compatibility/etc. at that time.
Update:
ThePNY 128 GB Card just arrived:
I installed the card,a pop-up appeared stating the card was either blank or has an unsupported file system.
Upon tapping on the pop-up,I was given the option to format the card.
Phone successfully formatted the card,stating 119GB of storage is available.
This works for me,I'll probably get a couple more from the same seller (B&H VIDEO/PHOTO).
For those who may prefer Sandisk,their most current/updated version is on sale today (7-14-15) @ AMAZON for $59.99 +tax & shipping.
http://www.amazon.com/SanDisk-Memory-Adapter-SDSDQUAN-128G-G4A-Version/dp/B00M562LF4
I have lexar from ebay which its has been the best for my taste out of all i have had
Premium memory solution for sports camcorders, tablets, and smartphonesQuickly captures, stores, plays back, and transfers media files, including 1080p full-HD, 3D, and 4K videoLeverages UHS-I technology for a transfer speed up to 633x (95MB/s)*Stores more than 15 hours of HD video; 33,000 photos; or 28,000 songs**Includes high-speed, Class 10 card and USB 3.0 readerLimited lifetime warranty for card and one-year limited warranty for USB 3.0 reader
Edited::: sorry i didn't wanna sound like a commercial or ad @ all... I just copied and pasted info... But to be quiye honest... I work in media editing. Vid,aud,etc.etc.. N the need to transfer raw vids n audios as fast as i need through my device n server. even wireless this has been yhe best. I still have a samsung.edgepro, sandisk ultimapro, pyn platinum... All full all functioning... But as performance "FOR ME" its this one.
No apologies needed,makes sense to use the mfgs description.:thumbsupdroid:
FWIW,I do it all the time,especially when answering a help request/carrier/mfg/spec data......
