Apps Expanded notification layout attributes can not be found 'No resource identifier found for attribute
omedries
I'm using the big image notification template as provided in the SDK (xml below). But I'm unable to compile my project after I have added this layout.
Even though I'm using the Schema: http://schemas.android.com/apk/prv/res/android which should provide layout_minHeight and layout_maxHeight.
Why do I have this problem and how can it be fixed?
Error(5) No resource identifier found for attribute 'layout_minHeight' in package 'android'
Error(5) No resource identifier found for attribute 'layout_maxHeight' in package 'android'​
<FrameLayoutxmlns:android="http://schemas.android.com/apk/res/android"
xmlns:internal="http://schemas.android.com/apk/prv/res/android"
android:id="@+id/status_bar_latest_event_content"
android:layout_height="match_parent"
internal:layout_minHeight="65dp"
internal:layout_maxHeight="unbounded"
<ImageView
android:id="@+id/big_picture"
android:layout_height="192dp"
android:layout_marginTop="64dp"
android:layout_gravity="bottom"
android:scaleType="centerCrop"
<ImageView
android:layout_height="6dp"
android:scaleType="fitXY"
android:src="@drawable/title_bar_shadow"
<includelayout="@layout/notification_template_material_base"
android:layout_height="64dp"
<FrameLayout
android:layout_height="wrap_content"
android:layout_marginTop="208dp"
android:paddingStart="@dimen/notification_large_icon_width"
android:background="#CCEEEEEE"
<include
layout="@layout/notification_material_action_list"
android:id="@+id/actions"
</FrameLayout>
</FrameLayout>
Source: http://grepcode.com/file/repository...otification_template_material_big_picture.xml
