Help Expanding memory with microSD to sd adaptor??
nitramus
I would say that the adapter would probably work. The problem would be getting a card that large to work. Most phones say they support up to 32 gig micro sd card, some are saying 64gb now. I don't know if this is because of hard/software limitations in the phone or if they just can't make anything bigger than a 64gig microsd yet. 256 gig in a phone would be redonk but AWESOME! :D
Not even that is enough ^^
HOW??? Are you using a standard usb to micro? I've used CIFs before to mount network drives. At least I know you can mount NTFS & HFS volumes now.
This only works on devices that support USB OTG. Should be any device with OS > 4.0 iirc...
All you need to do is not plug the USB OTG adapter in your device, then you can connect almost any USB device, even hubs...
you just gave me a reason to go back to JB. If I understand correctly there should not be any hardware restriction, all you need is the proper software which is os 4.0+...
It might also be hardware related, I ain't sure about that...
Just checked over at XDA and it might be possible to use OTG with the Desire... A kernel that supports that is required though...
