experts!!! Skype android 2.2.1 problems!! help
amr1406
i had phone name (BEE 7100) 2.2.1 OS. But when i installed Skype for Android, it said "application (skype) is in compatible with the system? even my phone have 2 camera ???
Not an expert, but according to the Skype app description, devices using version 2.2 can only use the rear facing camera. Most likely your phone lacks the hardware to be able to run the Skype software.
You might try contacting Skype to see if they have a solution, or maybe look into rooting your phone and installing 2.3
well the phone have rear facing camera ?? i think problem is the Os 2.2.1 not allow for cheeps phones can make video call ?
need to be cracked or updated to 2.3 but i don't know how to update it ,,
i did download Yahoo! Messenger ,, then ask me to download plug in for enable video and voice call , i click in get the plug ,, android market not allow it ,,
so i used another website to download the plug ,,( Yahoo-Messenger-Plug-in-1.5.apk )then i did download it and i allow unknown sources.. so its works now but skype not working :(
