Root EXT 2 Partition not recognised
Sheshnag
I am currently using Gen 1 Blade with Swedish Spring rls 5. The ROM is suppose to support Darktremor A2SD. I have partitioned my SD card using Easeus. 1st partition - 3.5 gb FAT 32, 2nd partition - 500 mb EXT 2. Both set as primary.
I have checked and rechecked the partition in Windows and all seems fine. However 2 things are happening:
1. When mounted the partition is not recognised so I can not use any data2sd, link2sd app or script.
2. using some apps from the market it looks like the partition is not being used and with some apps telling me the EXT partition is not mounted.
Can anyone please help me with how to deal with this?
