schwim
Hi there everyone!
I had finally had enough of the low space warnings and against my better judgement, installed the EXT4 ALL mod. I updated CWM to latest, did a nandroid backup and installed the no data limit normal dalvik mod.
Upon reboot, the phone seemed to have gotten half-assed amnesia. My account was still listed and it synced, but until the sync, all my mail, contacts, etc. was missing. Any non-stock apps had lost their data. I initially thought it was no big deal as I was willing to set everything back to rights if it was going to solve my space issue.
Then I began running into my issue with purchased apps. For instance, aWallet Cloud. It wouldn't sync because it couldn't verify my license. No biggie, I thought. I will just uninstall and reinstall. Uninstall went fine, but Google Play says I don't own the app. After looking, every app I've ever paid for no longer shows as owned and wants me to purchase again. If I try purchasing one again, I get "Error retrieving information from server. [BM-PPH-01]".
I'm not sure what to do. I tried removing my google account from the phone in an attempt to add it back and resync, but it won't let me remove the google account due to applications being bound to it(the same applications it says I no longer own).
Any ideas? I'm all ears if you have one
Thanks for your time!
