Hi All,
Has anyone had an issue (or better yet, resolved it) with the lockscreen timeout? I've had to turn off the fingerprint scanner and go with the pin login, because the timeout is too quick. After pressing the home button to activate the screen, it seems you get about 3sec (yes, I timed it) in which to bypass the lockscreen and get into your phone. I was having a success rate of about 1 out of every 10 times getting in with the fingerprint scan. The screen would timeout before it had a chance to recognize. Or in some cases, it would recognize, the screen would turn off, and I could hit the home button again and it would take me right in. Very annoying process just trying to get into your phone.
Also, a ding on the pin login... for some reason they've crammed the keypad into the bottom 1/3 of the screen. So the numbers are tiny and it's easy to fat-finger your pin. Not sure why they're not using more real estate for the keypad. Just strange.
