extend ringing before goes to voicemail
  • Start date Start date
A
Android Question
Guest
Phone model: samsung galaxy GT-I-9300
I want to extend the time the phone rings before it goes to voicemail as I keep missing calls.
Is this even possible??
Thanks
Collette
Hi and welcome
Yes it is normally possible to extend it up to 30 seconds or down to 5 seconds.
How you do it depends on who your carrier is, its completely different for some, but this works for many
On your phone dialer dial
**61*VOICEMAILNUMBER**SECONDS#CALL/SEND
where VOICEMAIL number is the number of your voicemailbox including international codes ie +33123456789 and SECONDS is the delay time before going to voice mail - it needs to be one of 5,10,15,20,25 or 30
I suggest you call your carrier to find out their method if the above does not work.
Roger
