When purchasing a battery its important to consider the Milliamparage of the Cell Unit. I suggest you inspect the originally supplied battery that came with the Unit and keep sure to match all the specified information except the Milliamps available eg: 1900ma/h is smaller and wont last as long as a 2200ma/h battery. So long as the model details remain the same you may increase only the Output Voltage amounts, the higher you go the longer the cell will emit power. I hope this helps.. CheersI have a couple of questions about extended batteries... do they really extend battery life and if so by how much? Do they have the same physical dimensions as the the default battery? And finally what are good brands to buy from? Thanks!
