Accessories Extended Battery Cover Stuck?
TozyJay
So I just installed the extended battery and cover on my Droid 2. This is embarrassing, but the cover seems to be stuck on there super tight. Has anybody else had problems with the extended battery cover? :o
Not trying self-bump, just wanted to let you all know what happened. Turns out one of the hooks that holds the over on was bent. Took it the Verizon store, the guy tried to get it off and couldn't. Eventually took in the back and came back less than 2 minutes later with it off. I'm scared to know what he did to remove it. :D
