Extended battery found.
unnamedny
Android Expert
Since it's a hot topic I did a research. I'd like to point out that I'm nowhere associated with this seller. Also please contact the seller first to find out if it's going to fit LG motion.
seller states "This battery is safe to use, identical in size & shaped to the original manufacturer's batteries and far better value for money. So with an extra battery on hand you can ensure that you never run out of power again!"
1
GOLD 2680MAH BL-44JH BUSINESS BATTERY REPLACEMENT FOR LG OPTIMUS L7 P700 | eBay
1
Ordered the battery and just got it. It works fine with the motion. When it came it had 70% charge, it's been 20 hrs and 43 minutes and it's at 20%.!! I'm letting it go down to 5% and then charging it, hope the long life continues.
Did u order this exact one?
Yeah, the Optimus battery won't even lay down flat/insert in the motion, enough of this crap already.
Enough of what crap? Look at the attached files. They show the battery in the phone and out of the phone, plus the phone closed to show that the cover fits perfectly. I have no reason to post untrue information. I post here, and also in xda - take a look at my stats over there. The battery fits my phone perfectly. I asked the seller and he confirmed before I bought. I don't buy from eBay unless the seller has more than 1,000 transactions and a rating over 98%. Maybe you're not placing the battery the right way. LOL
This battery is for the Optimus L7. I don't know if that's the same as the Optimus. If they're not maybe that's what's causing the confusion.
Read carefully before you post, it will help keep your foot out of your mouth. :)
Edit : after a short Google search, the phones are indeed different.
Chicle
Any increase in battery temp? does the phone get hot? also any time yet on how long it lasts with full charge?
Chicle
I haven't noticed any temperature increase, but I really haven't been paying that much attention. When I received the battery it had 70% charge, and 20 hours and 43 minutes later it was down to 20%. I'm letting it discharge further to charge it again. I don't have good stats to give you, since I took the battery out to take the pictures I attached, but I'll post the results, once it goes through another cycle.
good find but why does it look warped or bubbled the gold covering looks like there is something wrong with it
