Root Extended battery help
The fact that you put the word "ONLY" there suggest you already know the answer lol.
That's terrible. I have a 1650 mAh battery and it pretty much lasts me all day on one change.
For a 3500 mha battery its really bad, maybe you need to calibrate it..
Im using a 4200 mha battery with my S3 and its amazing take a look
This is from the motion but I wanted to share. Stock battery
So all I have to do when I get a extended battery for my connect I just have to calibrate to make sure I'm getting the battery I'm supposed to I'll try it and see
