Extended battery in stock size?
Bulldog
Hi all. My Incredible had a stock 1300mah battery but you could find batteries with similar dimensions in 1500-1750mah that fit under the stock cover (and in normal cases). Is there such a thing for the Note? Like maybe a 3000mah or something else worthwhile?
There's a 2650 by Mugen. Also, they say they have a 5400, but I'm not sure I trust it. I've read conflicting reports that it's not compatible with the i717.
The i717 compatible (most likely due to the back cover, and related antennae) battery from Mugen will be available May 4 (or today). Mugen and Seidio are two of the more reputable battery brands. Their power ratings are typically accurate, though no one is mfg. at "five 9s".
A bump of just 150mah hardly seems worth it. Flipside is an indication that maybe Samsung did the right thing and basically maxed it out to begin with.
Well I might buy an extra battery anyway so if I can get one that's supposedly more than 2500mAh from a reputable source then I'll go for it.
Im leaning more towards the Hyperion battery case when im planning to be away from a charger for awhile. Another 2800mah without shutting down and ripping my phone apart to switch batteries.
