i was looking for an extended battery.i'm running cl14 and the battery life really doesn't change with or without the battery app.the longest i have gotten it too last was 9-10 hrs and thats with almost no use.
Some apps re-spawn themselves. Meaning that the task killer may spend all day long playing "whack-a-mole".
Censlow: How are you running gmail with 4 accounts? 1.5 only supports one google account. Are the other 3 setup as POP/IMAP?
-SF
But does your battery meter jump around at all? I'm not sure if u use a battery meter but when I do mine will jump from 90% to 70 then in a like 2-3 hours tops it plumits down to 15%
