You seriously won't need one unless you very heavily use the device for more than 8 hours a day. After 5 hours of intensive use, I got to about 55% battery with the screen at 50% brightness. This included using LTE, texting, playing games, downloading apps, and web browsing. Non stop.
Decided to put off getting an F6 for now. Will wait for more user experience and an extended battery.
Thank you.
Is this battery much better than the stock battery?
New Extended Slim 2500mAh Battery for LG Optimus f6 MS500 MetroPCS D500 T Mobile | eBay
After 3 average workdays (for me anyways, I'm not on my phone a whole lot while AT work) and not recharging my phone, with my usual 3 hours of phone use for the ride to work, break, and back, my phone was at 44% battery when I finally plugged it back in.
I will be doing a real world test to see how long the battery can go at 50% brightness till it hits 15% if that helps any. But this battery is super long lasting.
Apparently no one knows how to properly train your battery, because i get about 11-13 hrs of extreme use where my screen is off for about 45 min the entire day... i love the battery in this phone with minimal use i get 2 days outta the phone and if you charge from a usb port it slow charges and get a better charge.. jus need to get some roms and tweaks going for this phone
I have had the F6 for 2 weeks. I think I have a problem with the battery. I disconnected 3G, data, mail sync,... . I must charge the phone all days. For example before going to sleep the battery was 100% and the morning, the battery fell below 40% without any use. I had the KITKAT version.
Informations about battery uses (approximatly) :
-Android system : 20%
-standby Cell : 20%
-innactif phone : 20%
If you have advices.
