Extended Life Battery Question
pbmac
Hi,
I realize there are alot of extended battery threads out there, and I have read a bunch, and I'm still not sure about a couple things.
I presently have the original battery, and I'm using the snap on case and holster( from VZW), which I like. From reading the threads, it seems I won't be able to use this setup if I get an extended life battery. If this is so, what setups ( holsters etc ) are available, and are any better than the others? If you know of a good thread explaining this, please point me to it.
Also, does having an extended life door/cover affect the signal performance at all? I'm pretty sure the antenna(s) is/are in the cover.
Thanks for your time.
ps. I'm presently reading all I can in here regarding battery usage, and how to increase battery life:)
Check out these threads over in xda:
1900 mAh batteries - xda-developers
1800mah Mugen Power battery? - xda-developers
You will learn a lot about available options for extended batteries that fit stock.
If you really want an extended battery I have seen one case that fits it:
http://androidforums.com/htc-droid-...ase-fits-extended-battery-incredible-2-a.html
Otherwise, check out this:
http://androidforums.com/htc-droid-incredible-2/326546-incredible-2-battery-saving-tips-thread.html
if you want to make the most out of your stock battery.
Thanks, that's a pretty informative thread, the one regarding things to do about reducing battery draw.
Can I ask you here about "Phone Idle"? My display shows using 56% of the battery, and the next biggest is Phone Idle at 16%...what is it? Thanks...
