piccasopete
As a new Samsung Galaxy Ace owner I am fed up with the phone only ringing for a short time before going to Voice mail. Can anyone help with extending the ringing time please?
This has lots to do with your carrier and not much to do with the phone....
As a new Samsung Galaxy Ace owner I am fed up with the phone only ringing for a short time before going to Voice mail. Can anyone help with extending the ringing time please?![]()
That solution worked PERFECTLY just as you described on my Samsung Y in Australia with Telstra as provider 9Sep2013. Thank you SO SO much. Yes 30sec is the max. Cheers Garry
- On your phone, dial *#61# and click Send.
- Some information should be displayed: number that the calls are being forwarded to and the delay before the forwarding engages.
- Write down the number (including +1)
- Dial **61*+1xxxyyyzzzz*11*30# and hit Send. +1xxxyyyzzzz is the number you wrote down previously, 30 is the delay in seconds. The delay can be set in 5 second increments, 30 is maximum
- Dial *#61# to verify that the new settings are active.
