Help external Keyboard is a POS
lance-tek
Member
Droid 2 Global (it is running 2.2 for the OS)
I am trying to use the external keyboard to put in a backslash ("\") but hitting the ALT + SPACE (should give me SYM) does nothing. ALT LOCK doesn't seem to work at all either.
I am having better luck with the virtual keyboard but I thought I would ask if this is an issue with the DROID 2 (base) as well? Or if it is just the D2G so far...
Thanks,
Apparently I've never used the backslash with the physical keyboard.
Just tried it to answer your question and it worked just fine.
"regular" D2, worked 4 me... Needed alt + space
Worked also w/ Swype virtual kb, preloaded.
Good luck...
David
