kabirarc
Hello Guys,
my phone is Karbonn Titanium s5 plus which is a MT6582 device (Rooted).
I have installed multiple custom ROMs for testing purpose. Now 2 days ago my phone rejected all custom ROMs but accepted the stock ROM and Sony Xperia V2 ROM. Now the problem is that after installation I find that the file manager is not working and DiskInfo app shows me that my external sd card is not mounted. I searched a lot about this error and was confused. my ext-sdcard is of 16gb and another app called APARTED shows out of that 11580 MB is showing fat32 fs and 4096 MB is showing ext2 fs and both of them are unmounted by the system by default.
when I connect the sd card to my PC with sdcard reader then it shows the contents and the card is absolutely OK.
So there are 2 problems :
1. I cannot install custom roms which I had installed previously in this phone via CWM or TWRP.
2. ext-sdcard not showing anymore in android file manager or any such file xplorers.
so guys any help will be appreciated !
Thanks and Regards.
Thanks and Regards.
