external sd card questions
ploehn
Just started up my new Acer. Read numerous threads and spent a long time regarding following question. I can't locate the external sd card (32G) directory. I have downloaded ES File Explorer, File manager HD and using these can't see where the sd card is located.
Also, I downloaded Moboplayer. Can I copy .avi movies to the external sd card while attached to my computer, then install same card into Acer and watch movies from card or must I move to internal storage?
I also think I'm understanding that if I want to read from an external hard drive I must first insure its formatted "FAT" rather than "NTFS." Correct?
Thanks, Steve
