D ds2306 Lurker Nov 22, 2012 #1 is there any way I can install apps from google play store directly into my external sd card If there is please let me know thank you
OverByter Resident Slide Rule Guru Nov 22, 2012 #2 What version of Android are you running and what phone?
lunatic59 Moderati ergo sum Moderator Nov 22, 2012 #3 If you have a phone with an internal SD partition, then it's probably more trouble than it's worth. If you have an older phone with no internal sd card partition then you can set the default install location to your sd card. You can read how to do it here http://androidforums.com/htc-explorer/568292-forcing-apps-install-sd-card-without-root.html
