keysdesease
Hello spiriters.
Here is what i have. A 32GB Sandisk card. Worked fine for months then one day the scanning for media files icon would never go away. Reboot phone and i got a bad card error msg needing to format. I removed the card put it in my PC, copied all the files off, put back in phone and had it format. Still same problem, so i put back in pc formatted using windows fat32.
Upon mounting the card back in, it mounts read only. Took back out and was able to write to card fine. Did this many times and even used linux to format. Plus used 3rd party softwater SDFormatter (supposedly low level formats, can't see how this is possible) but still has the same problem upon mounting it in phone.
I use another sd card and the phone has no problems. But if the 32gb card is bad why are my pc's able to write to it? With the directories copied onto it the phone see's it but only ro?
Any ideas??????""
Any ideas??????""
