Hello All
I wonder if anyone can help please. I have updated my Note to 4.1.2 and now when I connect to my computer (via a cable) there is no way to safely disconnect. There was an option to do this on the phone before with the original OS.
Since I have updated I have had an SD card fail (32GB) and I put a 64GB in and the same thing has happened after two weeks.
It is really annoying because as I transfer programs to the card to leave the internal memory free, I loose the programs on the card.
I do suspect this is because I just unplug the
phone instead of the old way of using software to disconnect it.
If anyone can help please it would be very much appreciated.
Kindest Regards
Eric
Kindest Regards
Eric
